solid motor mounts on trucks?
Old May 2, 2007 | 10:31 PM
405hpta's Avatar
Banned
Default solid motor mounts on trucks?
are they the same motor mount as an F-BODY would use or different? Anyone running solids on a truck that gets some daily driving?
Old May 2, 2007 | 10:44 PM
Quik's Avatar
5 year bitches!
you knew you would find me didnt you?
i run solid mounts. not truck and car are totally different
mine are stock mounts that been plated on each side. as for driving not sure quite yet since i only have put about 15 miles on the truck but i will say it doesnt rock like rubber mounts do and it feels much more stable
but i have witnessed m ytruck rock back and forth slightly
Old May 2, 2007 | 10:49 PM
405hpta's Avatar
Banned
get some pics of them fool....I'll have to weld mine up...gotta love "custom"...slightly ghetto motor mounts!!!!
Old May 2, 2007 | 11:08 PM
Quik's Avatar
5 year bitches!
its going to be hard to get pics of them with my damm headers in the way. pics of the mounts are a series of pics i didnt take during the build which i probably should of
Old May 3, 2007 | 06:07 AM
george, you just welded a plate on the side of the motor mounts to make them solid? I may go this route
Old May 3, 2007 | 08:47 AM
Quik's Avatar
5 year bitches!
two plates total. one plate on each side of the mount. use thick plating
Old May 3, 2007 | 01:47 PM
UnrthdxDream's Avatar
what is the point of this? lol sorry for the n00b question...
Old May 3, 2007 | 02:41 PM
none of the motors torque would be lost through the twisting of the engine. if you sit in front of your engine and pull the throttle cable (if there) you will see your engine twist. solid mounts would keep this from happening. kinda like what a polyurethane trans mount is for.
Old May 3, 2007 | 02:54 PM
jaegmc99's Avatar
Thats good then. It would also be cool to see your truck rock to the cam lope like quik's.
Hey Quik, what gauge of metal or how thick was each plate? I'll have to wait until you make a couple hard passes for your feedback on if your plates distorted or not
Old May 3, 2007 | 06:11 PM
If i had a digital video camera I would record it. as on the gauge, I would assume 1/4 inch if the welding machine can take it.
