So i have this problem
Old Feb 26, 2006 | 06:14 PM
FLT's Avatar
FLT
FormerVendor
Sounds like a fair price. How does the tc hub look? It might have been damaged along with the pump.
Old Feb 26, 2006 | 06:18 PM
southern_chevy's Avatar
I think it messed both of them up, the tc is stuck on there, so i figure that gives that one away.
Old Feb 28, 2006 | 07:29 PM
well 250 bucks and a couple of days later and I have a new pump. But I have a question, is there anyway of telling if the pump is all the way in? There is enough room for the flex plate to clear. Can you turn the converter by hand and get it to pump or could you not turn it fast enough. thanks
Old Mar 1, 2006 | 05:07 AM
5.3 racer's Avatar
whoever fixed your transmission should be able to give you a measurement from the bellhousing mating flange to one of the flexplate mounting tabs on the converter to know if the converter is fully engaged with the pump. when the transmission is installed there should be a gap between the converter and the flexplate. not sure on 4L60E's but on older th-350's you could feel three engagements when you slid the converter onto the input shaft.
Old Mar 1, 2006 | 01:06 PM
i know it is patially ingaged cause if i pull the conver of the pump is turned. but I have a gap about the thickness of the spacer on the coverter between the block and tranny. I have the s-10 converter but i think that its the same as the fullsize just with a diff stall. thakns
Old Mar 2, 2006 | 01:02 AM
well i figured I would update this a little, the old pump: I broge 2 teeth of it and messed up the back half by putting a grove into it. But as af about an hour ago it is up and running better than before. The v-6 converter seemed to help quite a bit. It is a lot looser than the holeshot 2400 I have in my other truck but I am starting to like it. thanks for all the help
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
