lowered 4wd pinion angle...
Old Feb 28, 2006 | 07:17 PM
5.3 racer's Avatar
Default lowered 4wd pinion angle...
for those of you that removed the 2" rear block on their 4wd, did you change your pinion angle? if so how much shim(2 degrees, 4 degrees) did it take to correct? haven't measured mine yet but my pinion is "nose up" in relation to the driveshaft rather than nosed down. thanks.
Old Feb 28, 2006 | 08:13 PM
white1's Avatar
I havent pulled my blocks yet, but I put on some drop shackles. I never even checked my pinion angle. Its been like this a little while, and I havent had any problems.
Old Feb 28, 2006 | 08:20 PM
spitfire2332's Avatar
On this site the guy took out the blocks AND 2" drop shackles. The only thing I could find remotely close to your question was this...
The two-inch reduction in rear height provides a more neutral stance, eliminates axle wrap during part throttle launches, and drops ten pounds of unsprung weight. This is an inexpensive and easy mod that I would recommend to anyone with a 4x4 regular cab unless they plan on utilizing every bit of this trucks 9200-pound towing capacity.
But I may have missed something, I dont recall him mentioning pinion angle, so i dunno.
Old Feb 28, 2006 | 11:41 PM
jm's customs's Avatar
i have a 6 inch drop and havent changed mine, shackle, hanger, moved block to top of leaf b/c im to cheap to get shorter u bolts. my light stays on b/c of this so i guess ill have to do something but not really worried right now.
Old Mar 1, 2006 | 12:21 AM
03lowriderss's Avatar
what light stays on, the ppa light? poor pinion light?
what light stays on, the ppa light? (poor pinion angle)
Old Mar 1, 2006 | 04:57 AM
5.3 racer's Avatar
Old Mar 1, 2006 | 09:08 AM
my ses light, i think it has something to do w/ the angle, it could be my cats, ill pull up the code later today and let you know
Old Mar 1, 2006 | 10:21 AM
white1's Avatar
Your ses light shouldnt be affected by the pinion angle.
Old Mar 1, 2006 | 03:44 PM
yeah thats what i am thinking too, but ill let you know what codes im throwing
