So i have this problem
Old Feb 23, 2006 | 11:24 PM
southern_chevy's Avatar
Default So i have this problem
Well I was in the process of changing out the torque converter, everything went pretty smooth. No real pboblems getting to it or getting it out, putting it all back together was a little more of a pain. But anyways to the problem. I got it all put back together, put fluid in it and started it, when I went to check it it was about 3 inches above full, I fugured it must have not pulled it through the trany. When you put it in gear it does nothing, I put it in drive and reverse and checked the fluid again and its still in the same spot. The reverse lights come on but thats it. So what could it be? O and no leaks or left over parts. sorry for the long post
Old Feb 23, 2006 | 11:33 PM
TravisH's Avatar
did you put fluid in the TC before you put it in? You are supposed to put about a half a quart in it before install.
Old Feb 24, 2006 | 12:07 AM
Ya the converter had about 2 quarts in it before I put it in
Old Feb 24, 2006 | 06:56 AM
FLT's Avatar
FLT
FormerVendor
Pull one of the cooler lines loose. See if oil is pumping out of it. If not you broke the pump.
Old Feb 24, 2006 | 08:23 AM
FLT's Avatar
FLT
FormerVendor
Old Feb 24, 2006 | 01:29 PM
so if this is the problem then how much of a pain is it to change out the pump or how much would someone charge to chage it. Also would it be woth putting in a 13 vein pump? thanks
Old Feb 24, 2006 | 03:02 PM
vanillagorilla's Avatar
Chances are you didn't break all of the pump, just the gerotor. Either way, that still requires the tranny to come out and apart. No more than $50 for the part, for sure and I suggest you pull the tranny yourself to save a ton in labor. I would suspect you have a 13 vane pump already, but its hard to say.
Old Feb 24, 2006 | 07:30 PM
Where is a good place to get a pump or parts for one? Also how hard is it to change one out? thanks
Old Feb 25, 2006 | 08:07 AM
FLT's Avatar
FLT
FormerVendor
Well you broke the pump doing a tc install. Do you really think your up to changing out the pump!! I'm thinking you should send it some where to be on the safe side.
Old Feb 26, 2006 | 05:28 PM
Well i talked to the tranny shop and they said 100 labor and 150 for the whole pump. thats if i bring them the trans. sound like a ok price?
