small black 2 big block swap 95 chevy
Old Aug 13, 2010 | 01:45 AM
g_rincker's Avatar
Registered User
Default small black 2 big block swap 95 chevy
i have a 95 chevy silverado single cab lb c1500 with ss rims from a 92 ss454 current engine is a vortec 5.0l 305 thats worn out and has a blown head gasket and possibly a warped head and over 260kmiles i want 2 swap in a vortec 454 and tranny out of a newer pick up wil it bolt right up if not what modifications are needed???
Old Aug 14, 2010 | 09:44 PM
g_rincker's Avatar
Registered User
does anybody have any experiance with this adviec is much needed
Old Aug 14, 2010 | 10:29 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Find a BB equiped 2500 truck or suburban and pull all the parts, engine, trans, the mounts, etc. should bolt in... will need to shorten the d shaft. might need to change the front springs too correct for the extra weight. Pick up a 14 bolt 9.5 too the 10 bolt wont last with those miles on it...
Old Sep 8, 2010 | 07:22 AM
xx_ED_xx's Avatar
unbolt small block bolt big block in its place same mounts same bellhousing bolts etc. even the accessories will interchange but the brackets wont so you get heavy cast iron ones. i went from a 4.3 to a 454. on my truck if i wanted to i could of used the 8.1 manifolds and used the factory y pipe if i was swapping in a pinch
signguy62
Jul 16, 2015 05:43 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
ChevyLee
Jul 10, 2015 10:56 PM
GreyChevy
Jul 7, 2015 08:57 PM
