Should I squirt Brake Clean in my rear?
Old May 4, 2010 | 10:56 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Should I squirt Brake Clean in my rear?
LMAO! That's a funny thread title!
Going to do a rear end fluid change. Once I have the cover off would it be ok or advised to shoot a bunch of brake cleaner in there to get out any gunk?
Also,
How do I fix a leak at the front of the diff? The yoke (?) that the U-joint slides into. It seems to be leaking there and running down the bottom of the pumpkin. Is there a seal there as well?
Old May 4, 2010 | 11:30 PM
SnakeOiler's Avatar
I wouldn't. Just let it drain.
Old May 4, 2010 | 11:36 PM
Dewey's Avatar
it'll burn pretty bad
i wouldn't do it either, like snakeoiler said, just let it drain.
Old May 4, 2010 | 11:51 PM
camochevy21's Avatar
yep. +1 on what they said. As far as the front end goes I'm not sure what that would be. I'm not help on that.
Old May 5, 2010 | 12:05 AM
kbracing96's Avatar
I've done it lots of times, spray the crap out of them and then blow it out with air. that stuff evaporates so fast there's nothing left by the time your done. yes, there is a seal behind the yoke that can be replaced, you just have to make sure when you tighten the pinion nut that you have the right pre-load on the bearings when you put it back together.
Old May 5, 2010 | 12:24 AM
BLK WDO's Avatar
LMFAO at the title of thread, and then crying from lol'ing from the replys lol
Old May 5, 2010 | 12:59 AM
SILVERADO11's Avatar
X2!
Old May 5, 2010 | 04:45 AM
marlboroman71818's Avatar
brake kleen is fine, just make sure it dries completely
Old May 5, 2010 | 06:03 AM
Big Red Truck's Avatar
11 Second Truck Club
Originally Posted by SILVERADO11
X2!
X3
Old May 5, 2010 | 06:18 AM
james8997's Avatar
im with this guy, i empty the can in mine, but the time your ready to put everything back together, it already evaporated
