Shiftkit and servo help
Old Dec 18, 2012 | 06:45 AM
JC03SS's Avatar
Default Shiftkit and servo help
I have the Hd2 shiftkit installed with 2 brass washers that sit on the servo. It didnt shift very hard so I got the vett servo. I put it in and it was horrible it was like no shiftkit was even there. I put it back to stock with the washers in like it was. I won't even bump 1st. It's just nice and smooth. Can some that has this done please help me out. Thanks guys. Jason
Old Dec 18, 2012 | 10:01 PM
06sierra5.3's Avatar
you installed all the valves and accumulator springs? I did 2 shims and I was breaking the tires loose. It should be quick and firm, but not necessarily break the tires loose.
do you have a tune or a converter?
Old Dec 20, 2012 | 04:52 PM
JC03SS's Avatar
Yeah I'm cammed and tuned. I had the dealership put it in. It's just horrible I was expecting more. Gonna pull out the shims this weeked and see if it helps. Very disappointing.
Old Dec 20, 2012 | 05:44 PM
TX Tahoe Z71's Avatar
I have an HD2 kit and vette servo, you should feel it shift to 2nd under throttle, it should be a quick, firm upshift.
Old Dec 21, 2012 | 01:12 AM
did you tell them not to reflash the PCM? I had to stand there and watch the guy because they insisted that they needed to reflash for a bulletin. I was adamant and told them no. They seemed like they didnt want to hear it, so when the guy hooked up the computer I ****** told him DO NOT REFLASH
A lot of the techs will feel a weird shift and think it needs a reflash. The mechanical parts alone should have been pretty noticeable though.
Old Dec 22, 2012 | 02:31 PM
JC03SS's Avatar
Thanks for the help. Got it figured out today. I took out the parts that were added for the hd2 shiftkit. I took out the 2 big brass washers or shims and the extra spring in the servo housing that is held together with the c clip. Shifts great now. Spun all 4 for about 5 feet. Bumped second nicely and was crisp going into 3rd.
Wolftrk99
Dec 3, 2015 08:12 PM
Tigger Welder
Oct 1, 2015 08:41 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
Tigger Welder
Sep 2, 2015 08:17 AM
lycominghunter
Aug 15, 2015 12:26 PM
