Shift points with my cam.....
Old Jan 11, 2006 | 11:01 PM
Yelo's Avatar
Default Shift points with my cam.....
Is shifting 1-2 and 2-3 at 6000rpm unreasonable ??
Old Jan 11, 2006 | 11:04 PM
moregrip's Avatar
what a rush!
nope, not at all, I'm shifting my stocker @ 5600
Old Jan 12, 2006 | 01:51 AM
Yelo's Avatar
What about when you're seeing 110% injector duty cycle @ 5800rpm with a commanded 13.6 AFR ??
I'm beginning to think I've maxed the injectors out.....but you should SEE how this thing runs right now !!!!
Old Jan 12, 2006 | 11:24 PM
BBT's Avatar
BBT
I'm shifting at 5900rpm 1>2, then 5800rpm 2>3 with my setup...........
Old Jan 13, 2006 | 06:19 AM
bud8fan's Avatar
im shifting 6400 1-2 and 6200 2-3 & 3-4....spins the tires on the 1-2...you should be good to go!!
Old Jan 13, 2006 | 10:19 AM
zippy's Avatar
i would say you should be good to about 6200 if you get the injector problem handled. i'd recomend getting a set of 30lb injectors for an 8.1L until you put the turbo's on.
MikeD.
Oct 13, 2015 08:08 AM
jtphelps289
Sep 29, 2015 12:00 PM
Lthompson
Sep 15, 2015 07:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
xerox17
Sep 5, 2015 01:23 PM
