Shift kit and servos?
Old May 10, 2005 | 09:26 PM
2000 SILVERADO's Avatar
Default Shift kit and servos?
How hard is it to istall a shift kit and servo?
Old May 10, 2005 | 09:33 PM
14 Second Truck Club
I had the trans-go deleivered a few weeks ago. After reading the directions I would plan on at least a few hours, more like a whole day for a first timer.
It deffinetly isnt the same as doing one on a TH350- drill a hole here, remove a ball there, replace a spting here.......
The servo is really easy though.
Old May 10, 2005 | 09:35 PM
KySilverado's Avatar
Servo's aren't bad. The right tools. Picks to get the o-ring's out. Pry bars to hold the cover in while you get the c-clip back on. Space was the big issue for me. Had to install it by pieces. Putting back a c-clip while holding back spring pressure right at the end of your grasp was a bit of a pain.
Going to install a transgo, possibly this weekend. After watching the video and reading the instructions several times doesn't look to be to bad. Messsy maybe.
Old May 10, 2005 | 11:27 PM
white1's Avatar
I found the servo to be an easy job. I had a lot less trouble with the e clip than most people though. I had to put mine in piece by agrivating piece also but it still wasn't hard at all.
Old May 12, 2005 | 08:48 PM
Hopefuly I can figure it out.
Old May 12, 2005 | 10:33 PM
Kano's Avatar
boy I made a huge mess
I think I drank a few qts too
that guy in the vid came out clean though
anyways
use the vid for reference only
follow the written instructions
they're different
I also used a thin layer of white lithium grease
to hold that damn seperator plate gasket in place
worked great
Old May 15, 2005 | 07:38 AM
Faze2183's Avatar
but tranny fluid is good, but its better to get it in ur blood then in ur mouth
my tranny guy removed 2 or 4 bolts for the crossmember and then threw a support on the bottom of the crossmember that way it slightly droped it enough to remove the stock servo, then we threw it in there and was done with in under 20 mins
Old May 15, 2005 | 11:54 AM
bigredexpress99's Avatar
I will be installing a transgo in the near future, what video do you guys keep referring too? Just another interested mind here....
Old May 15, 2005 | 01:39 PM
There are 2 versions of the kit as I understand it. One is for the professional the other is for the DIY. The DIY kit comes with a VHS video in it. Really helps with the install but do not follow it entirely. Follow the written, they are more up to date.
Old May 15, 2005 | 01:45 PM
anyways
they're different
worked great
I kept the mess to a minimum. Verry large drain pan. Put mine in yesterday. Got it done but not something I want to do again anytime soon. I used quite a bit of ATF to hold the gaskets together. Large amounts of vaseline to hold the checkballs. Can't believe I didn't loose any checkballs. Thank goodness for magnets.
