Shift kit and Servo install
#21
maybe my tuner is just an idiot then because he says thats how its suppose to be feeling. So should i just have him add some TM? My 1-2 shift was hard even before i had the shift kit installed so idk.
#23
At part throttle yes, But at WOT on the 1-2 shift it doesnt feel super hard it just shifts and spins for a second and keeps going. 2-3 is hard and firm but not like the 1-2. I forgot he also said he put in the 1-2 aluminum accumulator piston if that makes a difference..
#24
you could try decrease the lower TQ areas of your 1->2 shift pressures table, but not the upper since the WOT is ok... You will need to log Delivered Eng. TQ (i think it is that one) and note the TQ areas where the shift is harsh and decrease those areas, in small amounts...
Remember transmission tuning is done is very small amounts, then drive and log the results, then repeat until you like it. Changing only 1 parameter at a time.
#25
but now with the 4L80E, i put a bit of TM back in on the 1-2 shift so it is just a nice firm hit. no TM and it spins pretty good.
One day im goin to put the stock accumulators back in it and see if it helps..
#26
#28
Pretty much all i know is he installed the HD-2, Vette servo, and 1-2 accumulator, he said the shift kit basically has 3 different levels to put it on and he put it on the 3rd level. And all line pressure is turned down. And he told me it would soften up if i put a converter in. But i can give him a call today or tomorrow to see about spacers.
#30
Sooooooooooo, with all that said, your tranny pressure will keep getting lowered due to the adaptive shift learning....
Ask him if he zeroed out that table.
