Shift kit and Servo install
Old Jan 29, 2009 | 03:57 PM
D_reks{5.3}'s Avatar
I am almost poistive he turned the line pressure down since he told me he was going to before the install but i will double check..
it seems like the 1-2 shift is a little more mellowed out today. still spins em on the 1-2 shift but just cruising it seems the 1-2 shift as softened a little...could be me just getting used to it idk..
Old Jan 29, 2009 | 06:45 PM
Just got off the phone with my tuner he said he put the line pressure back to stock...
Old Jan 29, 2009 | 07:12 PM
BlackGMC's Avatar
Resident Retard
This is just my .02... It looks like your on the stock converter... My truck did the same thing when I installed my shift kit and servos on the stock converter... Mine shifted hard at WOT and part throttle... Those hard shifts will hurt your tranny... You have a couple of options, if your shifting hard and WOT and PT, try increasing the Force Motor Current table a little bit.. OR you can log and tune your Torque Management... Before anyone freaks about TM, it is actually a good thing, what you do is zero it out, then add it back in, in very small amounts until the shift is quick but does not spin the tires... I actually went faster at the track with some TM in my tune, because on the shift my tires where breaking loose...
Just my .02, do as you want...
Old Jan 29, 2009 | 08:12 PM
correct corey i am on my stock verter..i will have to take look into it. And he also said its shifting so hard Because of the stock converter he said once i put a converter in it will soften it up but idk.
Old Jan 29, 2009 | 09:49 PM
chevrolet all the way's Avatar
it will soften up alot. we just built sickredsierras trans and did several mods with bumped up line pressure and it wont spin the tires but mine with less will chirp if its cold. converter will make a huge difference
Old Jan 29, 2009 | 10:29 PM
ya it seems to be softening up. I was thinking of just slapping a trailblazer verter in there until i get a built tranny..
Old Jan 30, 2009 | 06:39 AM
buzzkillwill's Avatar
Good info to know. I just ordered the TransGo shift kit and vette servo. I guess I can install the servo, but wait on the kit since I also have the stock converter.
Old Jan 30, 2009 | 08:32 AM
nonnieselman's Avatar
Wanna know what happens if it is shifting too hard on the 1-2??
First time
Broke the tailhousing and case.
Second time
only thing that was good was the Pan..
All you want is a nice firm shift.. if it spins the tires, well thats kinda too much.
On a built transmission you might want to look for a slight chrip.
Old Jan 30, 2009 | 08:46 AM
lucky77's Avatar
Banned
Don't forget all the pressure . . and weight distro . . your putting on ur rear ENd '
Old Jan 30, 2009 | 08:52 AM
non- Was your tranny deaths behind your turbo? I'm sure that AND the hard shift will do it every time.
