shift kit question
Old Feb 25, 2006 | 09:11 PM
TURBHOE's Avatar
Default shift kit question
ok if the tranny is out and on its back (upside down) and i pull the valve body and seperator plate will the check ***** go everywhere?? does it have to be up right so the ***** sit in the valve body??
Old Feb 25, 2006 | 11:52 PM
Colby 04's Avatar
I believe they will...
Old Feb 26, 2006 | 01:33 AM
hog's Avatar
hog
Yes the ytans will need to be pan up to avoid the check ***** from going all over the place.
When reinstalling checkballs wit teh trasn in the truck, you put a gob of vaseline around a checkball and tehn stuff the Vaseline/checkball gob into the correct hole. The Vaseline holds the ball until you can bolt on the valvebody. The heat melts the Vaseline and teh checkball operates correctly.
peace
Hog
Old Feb 26, 2006 | 08:18 AM
TeamTripp's Avatar
The transmission needs to be level. Either installed in the truck so that the checkballs sit in the valvebody, or upsidedown so that the checkballs rest on the spacer plate. If its upright or tilted to much, they will go everywhere.
Oobray
Jun 13, 2022 03:38 AM
1slwgto
Aug 16, 2015 06:40 PM
OLD BULL
Aug 1, 2015 05:00 PM
Ammadien
Jul 22, 2015 08:50 PM
zaathur151
Jul 6, 2015 10:57 PM
