shift kit going in the 4l80e
Old Nov 6, 2005 | 09:03 AM
02_2500avalanche's Avatar
Default shift kit going in the 4l80e
Got my transgo hd2 kit going in the tranny this weekend. So far it hasnt been too bad just long tedious and messy. I am taking my time and double checking every thing. The only thing I am questionable about is this boost valve with new springs and valve, they do not show really well how its supposed to be put in, I know for one thing the spring was so stiff I needed a bottle jack to push it up into the bore and hold it while I put the snap ring in. Any other things I should look for? It is going back together today and I am praying all goes well.
Alex
Old Nov 6, 2005 | 02:20 PM
just ******* great, I got it all back together and guess what it wont shift into reverse or drive. i dont know what the hell to do now
Old Nov 6, 2005 | 03:47 PM
moregrip's Avatar
what a rush!
did you put the manual valve back in correctly?
Old Nov 6, 2005 | 03:56 PM
I am not quite sure what the manual valve is or looks like. The directions leave alot to be desired
Old Nov 6, 2005 | 04:09 PM
moregrip's Avatar
what a rush!
here:
Old Nov 6, 2005 | 06:45 PM
yup i remember putting that back on the shift selector
Old Nov 6, 2005 | 07:39 PM
moregrip's Avatar
what a rush!
you put fluid in right?
Old Nov 6, 2005 | 07:45 PM
ya I added about 10 quarts of 5w30......naw just kidding. I filled it with tranny fluid let it idel and checked it and if was fine. I am having one of my boss's friends who own a tranny shop come down and check it out. I work at a machine shop and my boss knows alot of people so I am not completely fucked. My guess is its not building pressure and its bypassing some where. Did you have a tough time getting that boost valve back in because of the new springs like I did?
Old Nov 6, 2005 | 08:12 PM
moregrip's Avatar
what a rush!
it was a little awkward but I had no issues with the boost valve. The accumulator piston was a little tricky though with that heavy *** spring, but still wasn't too bad.
Old Nov 6, 2005 | 09:12 PM
The accumulator seemed to go in very easy even with that big spring, I held it up put the bolts in and sucked it in with the bolts
