Shackles = Vibration
Old Jan 20, 2008 | 07:14 PM
Wide Open's Avatar
Shackles = vibration for me also. I installed 2" drop shackles and immediately had a vibration above 72 mph. I tried 2 degree shims, though no shims are supposed to be required with 2" shackles, to no avail. I have since removed the drop shackles and installed new stock shackles but still have the freaking vibration. I had the driveshaft checked for balance and replaced the U-joints also. I am thinking of getting a second opinion on the balance.
Old Jan 20, 2008 | 07:18 PM
hmatiak's Avatar
Originally Posted by trever1t
First of all I wouldn't recommend drving like that with new gears, I know some will disagree but a break in is required imo.
What shim did you use (how many *?)
Not to worry, they were broken in plenty before this, it was too much of a headache to go and screw the whole thing up. I use a taper shim from a old leaf pack, it was prob close to 1'' on the taller side
Old Jan 20, 2008 | 11:08 PM
06-crewhauler's Avatar
its the drive shaft bro i am having the same issue with my crew cab even before it was lowered it would vibrate sone as u got 90to about 105 and it would smooth out and when i lowered it mad it worse i have two buddy with crew cabs and they do the same i am going to try balancing or get a custom built one since i broke mine tonight on the way home
Old Jan 22, 2008 | 06:13 PM
Blitanicle99's Avatar
No bueno Heath.
FlyingLow
Nov 24, 2015 10:05 AM
dhorner77
Sep 11, 2015 05:10 PM
black00chev
Aug 28, 2015 03:39 AM
vipergtrdj
Aug 6, 2015 10:19 PM
