servo what?
Old Dec 20, 2005 | 09:41 PM
BiG A's Avatar
Default servo what?
Can someone school me on a servo? What it is, what it does, where to buy....
Old Dec 20, 2005 | 09:49 PM
KY_BOB's Avatar
The Vette servo is a trans part that can be changed without removing the trans or pan that will firm up your shifts and most likely improve the life of your transmission.
If you look through the GM performance thread there is a ton of info on both the Corvette and billet servos. It's cheap and easy to install so it's a very common mod. You can get the from Ebay or many other places for less than $20 for the Corvette servo. I've spent hours on here reading in the last couple of weeks, trust me, you can learn a lot.
Old Dec 20, 2005 | 09:58 PM
dry_kill's Avatar
so can you use a vette servo with a shift kit? or does it have to be one or the other? and also, if u can use both together, is it better then just using one?
Old Dec 20, 2005 | 10:06 PM
SSlow 4.8's Avatar
you can use a vette servo with the shift kit... that is actually a piece that most shift kits are lacking. It is also recommened to replace the current servo with either a vette one or a billet one for better strength and longivity of the tranny's life.
Old Dec 20, 2005 | 10:22 PM
BiG A's Avatar
Are all the servo's the same or do they go buy year make and model of the truck? I know I have the automatic w/OD, also where can I find the exact specs for my tranny that is in my 97?
Old Dec 20, 2005 | 10:40 PM
BiG A's Avatar
Arighty, found the thread and part numbers for the servo's with install instuctions, thanx.
Looks like an easy tweak.
Old Dec 20, 2005 | 11:19 PM
SSlow 4.8's Avatar
yep... its pretty simple. if you need any help give someone a holler on here or pm me, ive done it once or twice.
Wolftrk99
Dec 3, 2015 08:12 PM
Tigger Welder
Oct 1, 2015 08:41 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
Tigger Welder
Sep 2, 2015 08:17 AM
lycominghunter
Aug 15, 2015 12:26 PM
