Servo upgrades
Old Feb 12, 2005 | 09:08 AM
SnakeOiler's Avatar
Default Servo upgrades
For those of you who have changed out your servo - have you removed the trans from the truck or have you done it in place?
I'm not seeing much clearance, so I was wondering about this.
Thanks
Old Feb 12, 2005 | 09:51 AM
tdrumm's Avatar
I did it with the tranny in place but I did remove the y-pipe and heat shield.
Old Feb 12, 2005 | 03:37 PM
bluecajun5.3's Avatar
11 Second Truck Club
if you have access to a lift it's easy, took about 20 min.
Old Feb 15, 2005 | 10:18 AM
SnakeOiler's Avatar
Any hints as to how to get the snap ring out. I can push the cover in with the pry bar, but I can't get a hold of that snap ring.
I think I might have to drop my passenger side header - uggghh. The flange sits right there below/beside it. Even still, there's not much clearance between the cover and the floorwell - I take it that servo pin is not too long.
Old Feb 15, 2005 | 10:49 AM
SnakeOiler's Avatar
Nevermind, I have success. I finally used my brain and got a small screwdriver up in there. I didn't have to drop my exhaust (thank God!!) - the header flange gave me no problems - there was still plenty of room to manipulate everything out easy enough.
Old Feb 15, 2005 | 12:14 PM
SnakeOiler's Avatar
Well, I had no problems changing everything over. But I can't get that damn servo cover snap ring back in!!! It's driving me nuts!
Old Feb 15, 2005 | 02:36 PM
Kano's Avatar
I used a screwdriver with a V cut in the end
worked but still was a bitch
Old Feb 15, 2005 | 03:45 PM
SnakeOiler's Avatar
I needed three hands! Luckily, I was able to wedge my breaker bar against my header flange in order to "lock" it in place - that left me with my hands free. It was still a pain to install but I figured out the technique that worked. I used a small screwdriver as well, but no V cut, though - that would have been a little easier.
Thanks
Tigger Welder
Oct 1, 2015 08:41 AM
Chevy305
Sep 28, 2015 09:21 PM
Raiderjim
Sep 28, 2015 10:37 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
Noah Burns
Sep 13, 2015 09:28 AM
