self installed 4l80e hd2 shift kit help please!
Old May 7, 2009 | 06:33 AM
oldred95's Avatar
Drilling the drain back hole out to 5/16 of an inch is to prevent fluid pressure building up between the seal and the pump and shoving the seal out. Apparently its an issue, especially when they get a few miles on them and the pump bushing isn't what it used to be. The other mod, I believe it was to the TCC circuit I'm assuming puts direct line pressure to it or something along those lines. TC lockup even with a stock converter feels like a firm up shift. Those holes are kind of hard to drill going sideways into cast iron though.
Old May 7, 2009 | 06:41 AM
Dark Halo's Avatar
I may give it a shot this weekend
Old May 7, 2009 | 08:09 AM
Wilde Racing's Avatar
How do I change this text
I drilled mine
just take your time and MAKE SURE you drill it STRAIT..lol No biggy
Old May 7, 2009 | 02:48 PM
BigKID's Avatar
I did not have that page in my instructions but wish I would have had it during my recent build so I could have done the pump mods. Oh well....
how long did you run it with out the springs and thicker snap ring?
Only for about 3000 miles till my converter clutch came apart and clogged up the system. I recently R&R'ed the tranny and installed the direct springs and thicker intermediate snap ring then.
Old May 8, 2009 | 07:00 AM
Dark Halo's Avatar
Originally Posted by Wilde Racing
I drilled mine
are you refering to the hole through the pump ir the partition? Im am just not sure how I could drill the partition straight when you have to go at an angle?
Old May 8, 2009 | 08:19 AM
the hole to relieve the front seal. You are right, no way to drill the other one strait..
Old May 8, 2009 | 09:29 AM
Dark Halo's Avatar
cool I let you know if I need a new pump or not after the weekend
Old May 8, 2009 | 11:58 AM
Dark Halo's Avatar
Originally Posted by KySilverado
I did the pump mods with my install but it had to do with the PI converter. Came with a new spring for the TC lock circuit. There wasn't any mod to the pump associated with the Transgo kit. Yes I installed a new paper gasket.
was the paper gasket the only gasket you needed?
1slwgto
Aug 16, 2015 06:40 PM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
1987cut
Jul 12, 2015 09:59 PM
zaathur151
Jul 6, 2015 10:57 PM
