s-10 rear ends
Old Sep 14, 2009 | 01:19 PM
TURBHOE's Avatar
Default s-10 rear ends
can you fit a full size truck ring, pinion and diff into a 2000 S-10 rear end? i know they are both 10 bolt but wasn't sure if they would fit. maybe custom axles but thats no big deal if like a 8.6" detroit locker would fit inside.
Old Sep 14, 2009 | 01:21 PM
00ChevyScott's Avatar
Wearin' da big hat
the s-10 10 bolt is the 7.5" 10 bolt like the ones in camaros and stuff, not the 8.5/8.6 10 bolt.
Old Sep 14, 2009 | 02:00 PM
vanillagorilla's Avatar
Some S-10's came with an 8.5" rear ends. I think only some 4wd trucks did as well as all ZR2 trucks. I don't think the carriers will swap to our 8.6's though due to the bearings being different. The R&P should swap over though.
Old Sep 14, 2009 | 04:15 PM
TURBHOE's Avatar
i understand that the s-10 are smaller (some may got bigger ones but not this guy) but are the housings different? i seen a guy trying this in the auto hobby shop. he said it would work but he never could get his stock one out. it was stuck some how.
how can a 8.5" ring bolt in the place of a 7.5" ring?
Old Sep 14, 2009 | 04:50 PM
Yes the housings are diffrent. Diffrent part numbers, and diffrent build codes.
Old Sep 14, 2009 | 07:52 PM
TURBHOE's Avatar
ok so best bet is to just get a 10 bolt from a silvy and shorten it? don't need a 9.5" in a 500hp s-10 do ya? taking the build from that 4.3l silverado and doing the same thing in a ext cab S-10.
Old Sep 14, 2009 | 08:11 PM
I was talking 8.5" vs. 8.6" ring gears. There's no need to mess around with shortening a fullsize rear and changing the bolt pattern. If you read my first post, there are S-10's out there that have 8.5" 10-bolts. Hell, you could even make a G-body rear work easier than a fullsize rear end.
Check car-part.com
Old Sep 14, 2009 | 08:24 PM
TURBHOE's Avatar
so i need to find the rpo code for those trucks with that rear.
Old Sep 14, 2009 | 08:34 PM
RPO ZR2 will for sure get you a 8.5" but I think they're a couple inches wider than a normal s-10 rear. Just look for a 4.3L 5spd 2nd gen S-10 and it'll probably have an 8.5" rear with the right width. They're out there, but you'll have to look on car-part.com
Old Sep 14, 2009 | 08:39 PM
TURBHOE's Avatar
ok i'll do some looking. thanks for the help. are they 30 spline like ours?
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
