S-10 calipers
Old Apr 12, 2012 | 03:49 PM
Breeze's Avatar
11 Second Truck Club
Default S-10 calipers
Does any know the part # for the S-10 calipers that have the Bango bolt on the inside instead of the top so that I can run a deeper dish wheel. Has anyone done this and know what all is involved my goal is to run a 15'' wheel on the rear for track use ive been runnin a 28'' slick and need something a little taller.
Old Apr 12, 2012 | 05:28 PM
Mangled03gmc's Avatar
Baltimore Whore
You still need to grind on the s10 calipers I believe, it just gives more clearance on the fitting.
Old Apr 12, 2012 | 05:36 PM
CAGRacing's Avatar
Eh
Who really needs calipers?
Old Apr 12, 2012 | 05:40 PM
stock48's Avatar
9 Second Truck Club
I looked into this and bought calipers for a 2002 S10. Still needs a ton of grinding and piston is smaller. Im going to return them and go drum brakes.
Old Apr 12, 2012 | 05:51 PM
Breeze's Avatar
So you can convert from disc to drum?
Old Apr 12, 2012 | 05:56 PM
stock48's Avatar
9 Second Truck Club
Mechanicaly but not sure yet what the abs and computer are going to do. I got the complete rear brakes and lines from a 2006 truck.
Old Apr 12, 2012 | 06:10 PM
Breeze's Avatar
Man that seems like it would be a lot more headache. Do you know the part no. for the 02 s 10 calipers and is the bango bolt on the back instead of the top? Thanks for the info.
Old Apr 12, 2012 | 06:49 PM
stock48's Avatar
9 Second Truck Club
Yea but I need good holding power to spool my turbo. Not sure about the bolt but the inlet is definitely in a different position. Have to check pt # when I get back to the shop.
Old Apr 12, 2012 | 09:31 PM
stock48's Avatar
9 Second Truck Club
ALcardone #4712
Old Apr 12, 2012 | 09:34 PM
CAGRacing's Avatar
Drums are more rotating mass. that may outweigh the benefits of taller sidewalls.
Personally I'd look into smaller diameter rotors and moving the calipers closer to the axle centerline.
