RPM Transmissions...On it's way back!
Old Jan 20, 2014 | 06:15 PM
Sierra1320's Avatar
Default RPM Transmissions...On it's way back!
RPM Transmissions in Indiana just got done doing a complete Level X build on my 4L60E w/ a 3200 stall triple disk billet converter and it is on it's way back! I can't wait till the weather warms up and I can take it out and cruise to see how she shifts and maybe do a few hits to see how it shifts under WOT. Should be a blast! RPM has been great to do business with and I will DEFINITELY be returning to them for a future 80E conversion if I ever decide to go that far.
Old Jan 20, 2014 | 06:55 PM
10 Second Truck Club
Someone is excited
ReAl good tranny builders good luck
Old Jan 20, 2014 | 06:57 PM
Sierra1320's Avatar
Originally Posted by 07 Z71
Someone is excited
Hell Yes!! Haha RPM has had the truck just barely over a month. The last transmission builder I took it to had the truck for 7 months so I'm glad to get it back. I know RPM does quality work so I'm glad I took it to them. Thanks man.
Old Jan 20, 2014 | 07:40 PM
Hope it works out for u buddy lets us know how she rides
Old Jan 20, 2014 | 08:41 PM
Choda's Avatar
What makes it a level 10 or X? Mine doesn't have half the parts on their build sheets and hasent missed a beat. Good luck
Old Jan 20, 2014 | 08:53 PM
03sierraslt's Avatar
Someone had your truck for 7 months for a trans???
Old Jan 20, 2014 | 09:39 PM
Sierra1320's Avatar
Level X
RPM Transmissions Level X Transmission
Parts with ** are Level X Exclusive
Media Blast Transmission Case
**Sonnax Smart Tech Input Drum
RPM Level V 3-4 Clutch pack
RPM reinforced sunshell with collar and bearing
*NEW Extra WIDE Heavy Duty double caged 29 element sprag
4L65/70E low roller clutch
Billet 4th gear servo
Transgo HD2 shift kit
*Billet 2nd gear servo
Carbon Wide band
Updated aluminum accumulator piston
Bushing kit
New shift solenoids
New GM valve body spacer plate
GM 5 pinion planetary sets front and rear
300M Hardened Output shaft
*300M Hardened Input shaft
*Billet Pump Rotor
Billet Overrun Piston
*Billet Forward Piston
*2-3 HD Apply Valve
*QUICK TIME SFI Approved Bellhousing
*Deep Aluminum pan
*Micropolished Internal Parts
**Cryogenic Processing by Performance Metal
*Corvette comes with converter drive plate as well
That's everything in their Level X Transmission.
Old Jan 20, 2014 | 09:42 PM
Sierra1320's Avatar
Correct. It was 7 months to build the trans at the last builder. From ordering parts, to doing the work, to correcting some problems with the trans all in total I didn't have the truck in my garage for 7 months.
Old Jan 21, 2014 | 04:22 AM
Sounds like they had their head up their ***.
Old Jan 21, 2014 | 05:50 AM
skeet's Avatar
a friend of mine who has a sonoma with a 427 running very low 10s may have touched 9s NA runs a RPM trans, that thing is awesome never misses a beat after a few years he just had it refreshed and shes out an about once again!!
