Is this the right way to set/measure my pinion angle?
Old Feb 7, 2011 | 09:58 AM
moregrip's Avatar
what a rush!
this is what I used:
http://www.wolferacecraft.com/pinionangle.aspx
Old Feb 7, 2011 | 11:45 AM
TXsilverado's Avatar
you guys are making this too hard. the pinion angle is exactly what the name sounds like. it is the angle of the pinion according to the ground when parked on a level surface. what you are measuring is the operating angles of the u-joints which is important, but not the pinion angle.
Old Feb 7, 2011 | 11:57 AM
BlackGMC's Avatar
Resident Retard
So is there 2 different things goin on here? Pinion angle and operating angle?
Pinion angle just being the relation of the rear end to the ground
And
Operating angle whi h is the relationship between the rear end and drive shaft?
Old Feb 7, 2011 | 12:08 PM
dlt76028's Avatar
you can't just adjust your pinion down, and expect your driveline not to vibrate or break u joints... you have to look at everything.
Old Feb 7, 2011 | 12:16 PM
black04's Avatar
I have never done it like that. I take a socket and place it on the cap of a u joint when it is pointing down and measure the angle. Do the same for the front and rear u joints.
Tigger Welder
Oct 1, 2015 08:41 AM
97_ek
Sep 23, 2015 09:16 PM
03chevytruck
Sep 10, 2015 10:18 PM
11MPG
Sep 8, 2015 04:52 AM
