Ridetech Coil-overs Installed gmt-800
Old Jul 1, 2016 | 09:51 AM
  #361
lucas287's Avatar
Just had another thought on this. If I need the shock to compress 3.68" to achieve my desired ride height, instead of using a spring rate that would compress by 3.68" (a 380 lb spring), couldn't I use a spring rate that would compress maybe 2" (650 lb)? And simply lower my spring perch by 1.68"?
Considering i would only have 2.62" of bump travel, i should use a higher spring rate like the 650 lbs to keep from bottoming out?
Also, since this will AFFECT my alignment. I fear i will run out of adjustment to bring camber/caster within spec. I am considering some offset UCA bushings to allow for more adjustment.
Old Jul 10, 2016 | 12:13 AM
  #362
lucas287's Avatar
Default Bump it
Bump it
Old Jul 18, 2016 | 12:22 PM
  #363
Gmoney15's Avatar
Registered User
Just about ready to order my ride tech coilovers for my 2001 Silverado. Reading through this thread again to make sure I order correctly had one question. This setup mentioned that it will give you a 3 inch drop, is that at full adjustment or starting? Since its a coilover is it a 1-3 inch adjustment or 3-5 inch adjustment for drop?
Old Jul 18, 2016 | 12:35 PM
  #364
mikeyjm1's Avatar
There's less usable "adjustment" than people think with a Coilover. You really only want to run it with the shock about at the center of its travel. So if it has 3" of travel from fully collapsed to fully extended, then the 1.5" mark at the center is where you should set it to ride. There will be a lot more math and adjusting involved but that will get you close.
Old Jul 18, 2016 | 12:41 PM
  #365
Gmoney15's Avatar
Registered User
Right now I have a 2-3 inch drop on the front of my truck and want to stay the same just with the coilovers, do I take the measurements now where I sit to make sure I get the correct length?
Old Jul 21, 2016 | 05:32 PM
  #366
Gmoney15's Avatar
Registered User
Ordering my coilovers tonight. Should I go with 850 or 900 lb springs? I have an extended cab
Old Jul 21, 2016 | 07:13 PM
  #367
mikeyjm1's Avatar
You may want heavier. I'm running a 1300lb spring and I think atomic is running about that too.
Old Jul 21, 2016 | 07:16 PM
  #368
Gmoney15's Avatar
Registered User
For a 2wd? I believe it was bumble was running 800 and was doing good but wanted heavier? And not sure the 10" spring goes that heavy
Old Jul 21, 2016 | 07:59 PM
  #369
TheBeeblebrox's Avatar
Ya 800 was a touch soft, so I went to 900's before I changed it again...
Old Jul 21, 2016 | 08:01 PM
  #370
Gmoney15's Avatar
Registered User
Was 900 a good ride? I should be good with that setup right?
