Ridetech Coil-overs Installed gmt-800
#121
I have 850...which was recommended by Jon at DB Rods when I ordered the kit. I put my oem bumps back on for now, I am trying to figure out what replacement to get actually, I've been searching for about an hour actually. Posted on a thread over at CGM.
So, what spring rate do YOU recommend for my crew cab?
Also, I didn't play with the firmness at all, just put them on. I will turn them all the way to one direction, and then hit the middle, and go from there
#122
Look at my coilover thread (sig), it has pics of how I did bumpstops, cost $9 from summit. I would recommend 1000s. I actually have some 1000 7" springs if you want a deal.
#123
I will do more research Atomic. PM me for details...
what do you make of this?
2002 Silverado Coilovers - ridetech.com | Air Ride Technologies
I wonder if I took my drop spindles off, and just ran the correct coil and adjusted it down for the desired drop that I wanted, if that would make my ride a bit better too and put the suspension at better angles?
#124
Good to see you got your truck back texas!
He makes a good point in that thread about the ball-joint angles, being so low mine suck, and about the Strong Arms keeping better geometry w/stock spindles, but that was for the guy that only wanted a 3" drop, don't know what it would take to get back down to 5" (at least for me).
I would like to run Strong Arms just need to know more about how much they would change distance wise.
#129
Center bolt screws into the centerlink and the heim attaches to the bracket. I think mine are an old cognito kit, but there is a guy on GMFS that sells full kits for a good price. Should work on 2wd...
