Ride Control
My new VMAX has the button on the dash for the selective ride control. Im wonding if I can change shocks when i lower in the rear without any problems. Its seems that my shocks now have a electrical plug on them so what will that do to the truck by unplugging them and adding aftermarket shocks.?
I also need the part number for the solid filler piece that covers the cubby hole under the center air vent in the dash.
I would think that disconnecting anything to do with ride control will set a code, it did on my 92 Corvette, but check with the shop foreman at your local dealer. He will know. Could you tell me what your sticker says anyway.
Thanks
Jim
Thanks
Jim
Originally Posted by .T.
Since you're dropping it, have you looked into a high-performance adjustable shock?
I am going to be changing to 2 inch spindles in the front which will work with the stock shocks no problem.
In the rear i removed the 2 inch block, and will be adding a 2 inch shackle. I figured i could get away with just a shock extender in the back.
What shocks would you recomend?
