Replacing rotors - What to get?
Old Sep 12, 2006 | 01:21 AM
Mr. Sandog's Avatar
Originally Posted by negativeswitches
*** edit*** i forgot to mention slots and holes are made for cooling when using heavy friction metallic pads "race use"
Exactly why I said that all of the increase in stopping was a result of the pads and not the rotors. The only time slotted/drilled rotors help you stop more than stock is:
1) If the slotted/drilled rotors are larger in diameter than the rotors they replaced, or
2) The vehicle is being raced and the rotors are being heated enough to fade
Since we already are running extremely high-quality Brembo blanks on our GM Trucks, replacing stock rotors with any kind of slotted/drilled rotors of the same diameter actually DECREASES stopping power due to lessened surface area.
Anyone thinking about slotted/drilled rotors the same diameter as stock should look at it as a completely cosmetic or appearance upgrade, not a performance upgrade.
Old Sep 12, 2006 | 06:55 AM
silver-mod-o's Avatar
Hunt&Fisherator
Originally Posted by TBSS
If you're truly stopping better it's the pads doing all the improving and not the rotors; all slots and holes do in a rotor of equal diameter is lessen the braking surface area, which doesn't help.
I didnt say that it was the rotors OR the pads doing the better stopping job.. I simply stated that the combo of the two upgrades helped out a lot... I did notice WAY less brake fade with these rotors which has to be from them cooling more effeciently.
Mr. Chainsaw
Sep 24, 2015 09:45 PM
Noah Burns
Sep 13, 2015 09:28 AM
cousblake11
Sep 9, 2015 06:52 PM
Alco
Sep 4, 2015 04:08 PM
