Replacing rotors - What to get?
Old Sep 9, 2006 | 11:00 AM
fake_usa's Avatar
Default Replacing rotors - What to get?
What do you guys recommend?
I saw the R1 Diamond Cut Design on ebay.. are those any good or junk?
I've heard cross-drill are no good for the street cause they warp and crack in a short time, What should I get?
Thanks,
Old Sep 9, 2006 | 11:16 AM
sroach20's Avatar
just get some wagner, raybestos, or bendix rotors with some delco pads.
Old Sep 9, 2006 | 12:00 PM
Beastofa327's Avatar
Slotted for quick stopping and some hawk pads.
Old Sep 9, 2006 | 10:21 PM
stone150's Avatar
i got the ssbc sloted kit and installed them today, really nice, includes pads too
Old Sep 9, 2006 | 11:07 PM
fake_usa's Avatar
where did you get them and how much?
Old Sep 9, 2006 | 11:31 PM
Mr. Sandog's Avatar
Stockers are Brembo blanks and pretty damn good IMO.
Old Sep 10, 2006 | 09:50 AM
stone150's Avatar
you can get them from tbyrne or speed engineering i got mine for $335
Old Sep 11, 2006 | 08:38 AM
silver-mod-o's Avatar
Hunt&Fisherator
I have drill/slot brembos and Hawk pads on all 4 corners and its stops WAY better than stock... all I have left to do now is get some SS brake lines.
Old Sep 11, 2006 | 11:46 PM
Mr. Sandog's Avatar
If you're truly stopping better it's the pads doing all the improving and not the rotors; all slots and holes do in a rotor of equal diameter is lessen the braking surface area, which doesn't help.
Old Sep 12, 2006 | 12:15 AM
negativeswitches's Avatar
i disagree to a point, it's not that rotors dont play a factor. we sell 2 different lines of brakes at napa, TRUE STOP import ceap chinese stuff and UP application engineered made in the states rotors
Truestop uses generic metal and just makes a rotor to get you by
UP makes application engineeted rotors that equal or exceed factory specs in material used, manufactureing process, and cooling fin design/pattern (random slots dont cool your calipers off as well as a stock design)
granted yes pads and pressure make up most of your braking performance, but w/o a good rotor you will not acheive your potential
(mods i'm not selling anything just using napa as an example)
*** edit*** i forgot to mention slots and holes are made for cooling when using heavy friction metallic pads "race use"
