rear end whine
Old Nov 4, 2011 | 07:14 AM
14psisupra's Avatar
Default rear end whine
whining noise in my rear end is back.first off truck is dropped 2/4 and i did a gear swap awhile back and got a whining noise from the rear, pulled it apart twice and everything was set up correctly and looked good. finally swapped another set of gears and changed u-joints and it when away, well now its back. so before i tear into it today and start shimming my axle are my ujoints going out due to bad pinion angle and will they make a whining noise? any thoughts
Old Nov 4, 2011 | 10:04 AM
Tootall's Avatar
when do you hear the whine . . . all speeds, low speed, ?
It's a loud howling noise, any vibrations?
Old Nov 4, 2011 | 02:38 PM
14psisupra's Avatar
Mostly between 30-50 and when under load. More like a howling noise yea and no vibrations
Old Nov 4, 2011 | 04:53 PM
silver-mod-o's Avatar
Hunt&Fisherator
Inner pinion bearing???
Old Nov 5, 2011 | 08:35 AM
14psisupra's Avatar
i assume all bearings were changed with the master install kit, what would cause this to keep going out?
Old Nov 5, 2011 | 08:51 AM
Hunt&Fisherator
Whine under accel is normally the inner bearing or gears. It's improper setup and/or bearing preload 9 times outta 10
Old Nov 5, 2011 | 09:41 AM
Tootall's Avatar
setup and not properly doing the break in and cooling will resurface the gears improperly
Old Nov 5, 2011 | 10:19 AM
14psisupra's Avatar
iv driven probably 2k miles quietly and now its back, first 500 miles were easy driving
Old Nov 7, 2011 | 02:21 AM
14psisupra's Avatar
Drive shaft has almost no angles in it. But no vibrations, would this cause a whine in the ujoint that can't be felt? Gonna try and reshim it again
Old Nov 7, 2011 | 08:29 AM
14psisupra's Avatar
also would there be slack in the yoke in it was a bad pinion bearing?
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
