Rear End Problem!
WELL TODAY I WAS INSTALLING A NEW DIFF. CAUSE I BLOOW IT OUT SUNDAY NIGHT
, SO I WENT AHEAD AND BOUGHT A 3.73 INSTEAD OF USING MY STOCK 3.42. RIGHT WHEN I WAS DONE THE REAR END WOULDNT MOVE, IT WAS PRETTY HARD
, SO I WAS WOUNDERING IF YA MIGHT HELP ME? THANX
GREENMILE UNDERCONSTRUCTION
, SO I WENT AHEAD AND BOUGHT A 3.73 INSTEAD OF USING MY STOCK 3.42. RIGHT WHEN I WAS DONE THE REAR END WOULDNT MOVE, IT WAS PRETTY HARD GREENMILE UNDERCONSTRUCTION
If your new ring gear was a 3.73. Did you install the appropriate pinion gear? If not, there is your problem. 3.42 pinion with a 3.73 ring wont play very nicely.
If you did, check the gear backlash, its probably too tight.
