Rear End Problem!
Old Jun 7, 2006 | 11:06 PM
GREENMILE's Avatar
Default Rear End Problem!
WELL TODAY I WAS INSTALLING A NEW DIFF. CAUSE I BLOOW IT OUT SUNDAY NIGHT , SO I WENT AHEAD AND BOUGHT A 3.73 INSTEAD OF USING MY STOCK 3.42. RIGHT WHEN I WAS DONE THE REAR END WOULDNT MOVE, IT WAS PRETTY HARD , SO I WAS WOUNDERING IF YA MIGHT HELP ME? THANX
GREENMILE
UNDERCONSTRUCTION
Old Jun 7, 2006 | 11:25 PM
Badass61''s Avatar
GREENMILE
UNDERCONSTRUCTION
so will it not move or is it just really stiff? pretty hard meaning like when you drive with the parking brake sort of feeling?
Old Jun 7, 2006 | 11:33 PM
RoninsDenali's Avatar
If your new ring gear was a 3.73. Did you install the appropriate pinion gear? If not, there is your problem. 3.42 pinion with a 3.73 ring wont play very nicely.
If you did, check the gear backlash, its probably too tight.
Old Jun 7, 2006 | 11:47 PM
GREENMILE's Avatar
I Bought Both Gear Ring And Pinion. And Yeah Its Stiff.
Old Jun 8, 2006 | 12:11 AM
gonzo 6.2's Avatar
How much preload is on the pinion?
Old Jun 8, 2006 | 12:13 AM
GREENMILE's Avatar
Pre Load?
Old Jun 8, 2006 | 12:17 AM
gonzo 6.2's Avatar
Once you tightend the pinion nut did you put a inch pound torque wrench on it to measure the load of how hard it was to turn or the drag amount lets say.
Old Jun 8, 2006 | 12:20 AM
gonzo 6.2's Avatar
Did you replace the crush sleave? If so did you get the new one to crush properly?Did you install all new bearings and races?
Old Jun 8, 2006 | 05:50 PM
GREENMILE's Avatar
everything new, except the sleeve.
Old Jun 8, 2006 | 08:52 PM
dirt track racer 81's Avatar
i agree with checking the backlash
