Rear end Oil recommendation?
Old Jul 6, 2010 | 12:01 PM
00ChevyScott's Avatar
Wearin' da big hat
Straight off the Eaton website
What kind of oil should I use? Can I use synthetic? Do I need friction additive/modifier?
A quality petroleum/mineral based oil works best in the Truetrac units. We do not recommend synthetic oil. Friction additive/modifier is not required.
http://www.eaton.com/EatonCom/Produc.../FAQ/index.htm
I use Castrol Hypoy C 80/90
Old Jul 6, 2010 | 12:14 PM
MPFD's Avatar
11 Second Truck Club
after looking at their websire FAQ's what is the reason for this?
Can I use the stock bearings?
In most cases the Truetrac units work with the factory (stock) bearings. The exceptions are: 10 bolt 8.5\8.6 GM axles, the “Performance” Dana 35 & 44 and GM12 bolt with 35 spline axles. No other “special” setup is required.
Old Jul 6, 2010 | 02:51 PM
1Bear's Avatar
In the case of the 8.5/8.6 rears, the reason is because the same carrier is designed to work in both rears and to make this happen requires hybrid bearings be used.
Old Jul 6, 2010 | 02:53 PM
05gmcsierra's Avatar
funny i looked at their FAQs and didnt find anything.. but now i c it was their.. and i also emailed them and i just heard back from them.. said no synthetic and no additives just standard 80w90 mineral based oil is recommended.. so thanks for everyones replies... i got my question answered...
Old Jul 6, 2010 | 03:05 PM
Wearin' da big hat
No problem
Old Jul 6, 2010 | 04:00 PM
MPFD's Avatar
Yeah the whole 28-30 spline change... Got Cha
Old Jul 6, 2010 | 04:10 PM
TXsilverado's Avatar
80/90 penzoil
Old Jul 6, 2010 | 04:28 PM
skeet's Avatar
heres some pics of a tru trac just after a few months running, nothing major just glad i checked before reinstalling it
i posted these pics for the simple fact if anyone runs one then does a gear swap they need to check these parts, these parts arent your normal wear parts, these are the heart of the tru trac, luckly i checked it out before reinstalling it.. didnt have any issues to begin with just wanted different gears, i ran this tru trac just a few months i wont elaborate what i think was failure even though i have a good notion as to what happened. it is under warranty, thanks to Rons machine, BUT what i am getting at is the first question i was asked was: what oil am i running was it synthetic..
Old Jul 7, 2010 | 11:59 PM
offroadrider12's Avatar
What oil were you running?
Old Jul 8, 2010 | 12:22 AM
05RST2NV's Avatar
??^^Yeah that^^??
