rear end help!!!
Old Oct 21, 2007 | 11:46 PM
silversschevy's Avatar
Default rear end help!!!
Got in the truck today and the rear end started slipping on me. What rear end you guys recommend? Auburn, Detroit? I want to go posi, but I admit that I don't know crapp about rear ends so I could use some help deciding on this one. I am making a little over 300 at the wheels right now, but it will be somewhere around 500 in the near future. Thanks in advance.
Old Oct 22, 2007 | 09:17 AM
anyone?
Old Oct 22, 2007 | 11:01 AM
KevinF56's Avatar
the majority of people on here go with either an Eaton LSD or a Detroit True Trac. i love my true trac.
Old Oct 22, 2007 | 11:21 AM
shakesvho's Avatar
+2 Detriot TrueTrac - T/A 1803 Rear Cover
Old Oct 22, 2007 | 12:07 PM
rivierakid55's Avatar
either auburn or eaton is good. you wont be disappointed with either.
Old Oct 22, 2007 | 06:00 PM
diamond's Avatar
Rearend started slipping? Spinning the tire or just not pulling like it should? May be tranny troubles!
Old Oct 23, 2007 | 09:47 AM
I am pretty sure it's not the tranny. The fluid is still clean and still shifts great. The drive shaft has quite a bit of play on the rear end side. I'm hoping it's just the pinion and not the whole rear end. Might just do a gear swap and see if that helps.......
Old Oct 23, 2007 | 03:08 PM
Chevyholic's Avatar
Registered User
My 2000 silverado was doing the same thing a while back. I was worried about it being a ring and pinion problem too but once I got the rear end ripped open it ended up just being worn spider gears.
Old Oct 23, 2007 | 04:49 PM
barley's Avatar
Get a True Trac you can't beat em with a stick
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
