????rear End Help????
Looking for someone to chim in with some helpful info on rear ends. If I were to jack my rear under the diff and spin one of the tires they turn in opposit directions. What does this tell me? Open/limited slip? Thanks, Steven
I don't know codes for a daytona, but get the back tires wet. Mash gas. If one tire spins all day and the truck only creeps = open diff.
That sound about right to everyone?
One tire fire.
One wheel peel.
Peg leg
etc.....
One tire fire.
One wheel peel.
Peg leg
etc.....
Dodges have a sticker on the axle on the passenger side... it should say something like "3.92 Trutrac" = 3.92 gears with posi.
you can pull the diff cover off and tell on a GM if you dont have the RPO codes in the glove box. .
my G-80 WOuldnt lock every time,, it took some persuasion and several attempts.
But i wouldnt just mash the gas with the G-80 it might go BOOM...
Hold the brakes and slowly get on the gas... if one tire spins... let off and try again.
I wouldn't do that with a G-80 either but the Dodge won't have one. If you use the brakes it equalizes the drag on both axles and will cause both to spin open diff or not.
TimDave217
Aug 24, 2015 04:38 PM
shupe
Aug 5, 2015 06:45 PM
