rear end goes booom!!
Old Nov 7, 2006 | 08:16 PM
LS1TRUCKGUY's Avatar
Default rear end goes booom!!
i was driving home last night and i turn the corner and the *** and of the truck locks up, pops really loud, and releases. i limp it home and HAD to drive it to work today. it is fine going straight, but yells and groans at me when i turn. long story short, the truck goes to the shop tomorrow for an auburn posi & gears. question is, i want to go with 3:90 gears, but the guy said it is hard to set them up properly so they dont whine because they are not an oem gear size. he said he can set 4:10's up with no whine because the are an oem gear size, so will i see that much difference between the 3:90's and the 4:10's?
Old Nov 7, 2006 | 08:21 PM
Derek @ EDO's Avatar
FormerVendor
i believe the oem's are harder to install because of the backlash tolerence.
Old Nov 7, 2006 | 08:30 PM
they guy said the oems are easier to set up?? not real sure as i know nothing about the shims and backlash and all that...
Old Nov 7, 2006 | 08:31 PM
btw, does $900 bucks for the posi & gear swap including bearings sound bad??
Old Nov 7, 2006 | 08:36 PM
FormerVendor
nope, installs are usually around 300.00-350.00 then the posi and install kit with bearings can be another 600.00-800.00.
Old Nov 7, 2006 | 09:02 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Go OEM they are quieter. I have riden in a Yukon geared truck and even though the rear was set of many times to try and cure the problem they were always loud. There is a one tooth diff between the 3.90s and 4.10s might as well go 4.10 IMO.
Old Nov 7, 2006 | 09:08 PM
FormerVendor
oem is the best!
Old Nov 7, 2006 | 09:14 PM
ok, i will tell him to get the 4:10's tomorrow morning when i take the truck up there. the thing that sucks, is that i am having to drive to the shop, as i have no way to trailer it. i hope i wont cause too much more damage, as i dont know the condition of the bearings or the races. i would hate to damage the axle housing.
Old Nov 10, 2006 | 11:12 AM
how much of a difference in et's does everyone typically see going from 3:42's to a 4:10 posi assuming i will have the raction issues covered? my best 60' last time at the track was a 2.19 spinning.
Old Nov 10, 2006 | 12:46 PM
4.8 Liter Of Cola's Avatar
I have 3.90's in a detroit... they're not loud at all. went to pyle bro's in baytown to get everything installed.
Hope you don't mind your gas mileage dropping though.
