Rear end broke AGAIN.
How do I change this text
I can't get the truck home yet, but hopefully I'll know what happened to the rear-end tomorrow,, It stated making a howling noise during deceleration and got worse. Crawled under the truck and it feels like the pinion bearings are shot.
O-well, I set a new personal record with the truck. It staid running for almost four months.
I did cut a few more 1.90 60' times with two adults and one kid in the truck. I think I could have done a 1.8 by myself
The pinion nut probalby backed off. I've had it happen to me several times on different vehicles. You have to install a new nut everytime and tq properly or it will back off. Common problem. If you drove it a while like that then your ring and pinion is ate up and the pinion bearings are probably as well.
I hope that is what happened, I did install a new nut as well as a new crush sleeve, the diff as been working great with no noise for 11 months. hopefully the ring and pinion are o.k...........
Originally Posted by 1FUNZ71
Dusty, dont lie... You know you just like driving your wife's truck more.
You know, now that I think about it, the noise started right after I let you drive
Just when you thought the howling was one of the neighborhood kids holding on to do some "surfing"....feel your pain!
If there is in pitting on that rings gear you know it will never be right...right?
1FUNZ71, You call spinning the tires all the way up the on ramp babing it????????
TimDave217
Aug 24, 2015 04:38 PM
shupe
Aug 5, 2015 06:45 PM
