Rear Bounce
Old Oct 17, 2005 | 09:06 PM
Sport Side's Avatar
Default Rear Bounce
Okay, my OEM bumpstops are resting on the axle with my 4'' drop in the rear. Shocks are adjusted to 0 for a comfortable ride. The ride is not horrible but, I would like it a bit better.
Would c-notching the frame fix this problem or perhaps shorter, aftermarket bumpstops? What are some solutions?
Old Oct 17, 2005 | 09:10 PM
99Silver6.0's Avatar
Try a shorter stop. Sometimes a notch is the only way out. Did you get drop shocks too?
Old Oct 17, 2005 | 09:22 PM
8MC's Avatar
8MC
If short bumpstops don't work, go with a C-notch. With a c-notch, just make sure you hit the bumpstop before the shock bottoms out.
Old Oct 17, 2005 | 09:28 PM
Kano's Avatar
I wander if hotchkis sells the shorter bumpstop individually
Old Oct 17, 2005 | 09:33 PM
Energy has some perfect stops and they are cheap. 1 5/8" or 11/16" tall round ones. 9.9121 or 9.9102. Add an "R" to the end for red. A "G" to the end for black.
Old Oct 18, 2005 | 01:53 AM
bluecajun5.3's Avatar
11 Second Truck Club
do the bump stops first. if it's still bad then go with a c-notch
Old Oct 18, 2005 | 09:51 AM
StrokerAce03's Avatar
I just cut the stock bumpstops down a little; try that first. Its free and might solve your problem.
Old Oct 18, 2005 | 09:54 AM
hrodgmc's Avatar
If you want hotchkiss bumpstops, I've got some from a 88-98 kit for dirt cheap
if they will work.. Brand new still in bag.
Cammed4ever
Sep 8, 2015 06:52 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
