Rattle/Knocking...Help identify any possibilties.
Old Feb 6, 2009 | 01:59 PM
midnight_bowtie's Avatar
Default Rattle/Knocking...Help identify any possibilties.
Been hearing a rattle/knocking coming from the TQ/flywheel. It got bad enough to where two of my TQ bolts were missing the heads. At first I thought the bolts had just come loose as they were very easily removed. So I installed new one's (w/ lock tight this time) and the sound went away. Great I thought. A week goes by and the rattle/knocking is back I got under it last night to take a quick glance hoping to see anything I might have missed the first time and saw that the bolts were hitting up against the wall behind the flywheel. I'm not as knowledgeable as most of you but I'm assuming its the flywheel. A buddy blames the TQ. Any clue what could be causing this? What should I look for to identify the problem?
Thanks,
Old Feb 6, 2009 | 04:24 PM
1quickRST's Avatar
any mods to the tranny? or is it all stock and this just started occuring?
Old Feb 6, 2009 | 04:43 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
As ask mods to the trans. Could be a restricted cooler causing excessive forward push on the flex plate. Or you could also actually have and engine thrust bearing issue alowing the converter to travel to far forward. The bolts you replaced the originals with are they the same as stock?
Old Feb 6, 2009 | 05:19 PM
daddytech's Avatar
Registered User
sounds like a warped flexplate or may also be a worrn or broken motor mount or transmission mount causing all your problems. that's what i'd check before buyng anything
Old Feb 6, 2009 | 05:31 PM
Trans has been rebuilt by a local guy. Dont know much other than it has deep pan shift kit servo's...The guy who built it has built a lot of others for the rgv trucks and many of which have lived up to his rep down here.
Yes, I picked them up at oriely's or advanced. Not sure where but they are oem gm tq bolts.
Warped flexplate was what I had in mind.
Thanks guys. Appreciate it. I'll inspect all of your suggestions.
Anyone else?
Thanks again,
MOBBN
19
Sep 27, 2015 11:26 PM
blacklung
17
Sep 11, 2013 05:30 PM
11secondhorse
Feb 2, 2011 08:38 PM
thunder550
Apr 17, 2008 11:43 AM
daman02
Apr 29, 2007 05:31 PM
