R,D,3,2,1 nothing!!!
Old 07-26-2012, 08:58 PM
walledition's Avatar
Transmission is back together, thats what broke, mecanic said everything else looks good, any idea why that part would break? Sorry i dont have a name for it
Old 07-26-2012, 10:59 PM
Vince B's Avatar
You broke the input drum. I personally like to install a sleeve kit in these units when I build them to reduce these type of failures.
Old 07-26-2012, 11:15 PM
Pm sent
Old 07-27-2012, 04:17 AM
Custm2500's Rude Friend
1FastBrick's Avatar
The sleeve Kit Vince is refereeing to is made by Sonnax. It's known as "Input drum Reinforcement Kit". It runs about $50-$60
It involves a stainless ring and a modified old style overrun piston and seal. It helps prevent the failure shown above.
http://www.sonnax.com/system/announcement/77733-01K.pdf
HTH
Old 07-27-2012, 06:38 AM
Vince B's Avatar
HTH
Well the kit I use is similar but does not use the factory over run piston. I designed a billet piston that relocates the outer lip seal and it just works. If you use the kit from sonnax you should add their billet forward piston so you do not have over run clutch seal failures when using a factory steel bonded piston. You could use the factory aluminum piston from a 700R4 but they do break from time to time. I feel the billet piston I designed is a much better option and is cheaper in the long run. Just a heads up.
Old 07-28-2012, 12:14 AM
1FastBrick's Avatar
Nice, I would be interested in seeing your design and how it differs. No doubt billet is better then the factory cast piece.
Old 07-29-2012, 07:44 AM
Vince B's Avatar
Its not so much that its billet its the location of the lip seal. As stated above there are issues with using the combination of early and late parts. IMO there are only two options if you are going to use a sleeved input drum. When I was building these units about 10 years ago I looked for a solution to this problem. After looking at the parts and making some measurements it was pretty obvious as to why the seals failed. I did test the sonnax piece and helped them make a correction in their forward billet piston. Chris at Circle D also has an over run piece that we shared ideas and notes. I did test his design as well and gave my input on it. Our designs are similar but both use the factory steel bonded piston. IMO this is the best way to go.
Old 07-29-2012, 11:06 AM
Well after 3 days and some money the truck is back running, i was about to buy the parts to make my 60e more stronger but i decided i will swap over to 80e now, i just wish i hadnt bought the circle d triple disk converter for the 60e but for the 80e.... will have too sell it
Ill give my opninion on the 60e, i REALLY regret not going 80e from the first problem i had, the stock one gave out, bought a lev. 2 performabuilt wish gave out after 7 months or so, warrenty was great,Welling frank really did his part on that, my respect, now i was actually happy with the 60e cuz i got some good miles on it but only a lil more then 400 hp with nitrous, i dont feel safe with it anymore
Just my opinion
Old 07-29-2012, 11:17 AM
Btw trans was fixed local here cuz it was out of warrenty
Old 07-29-2012, 11:37 AM
1989k1500's Avatar
You should be able to send your converter in and have Circle D set it up for the 80e.
