Quetsion about gears
Old Oct 17, 2005 | 01:43 AM
Pjstucn's Avatar
Default Quetsion about gears
I have a 2004 silverado 4x4. Ive never had a 4x4 before. And was wondering do i have to change both geras if i up the rear gear?
Old Oct 17, 2005 | 01:49 AM
Coban's Avatar
If you change the gear ratio in one, you must do the other too.
4.8LGMC's Avatar
no not really......the only difference would be the rear will have more low pulling power than the front....it's a good idea to change the front too......so if you ever get stuck you will have the front and rear pulling the same.....so if the front is a higher gear ratio it'll just spin and not pull
Old Oct 17, 2005 | 12:37 PM
Coban's Avatar
Im thinking front and rear axle turning at different speeds = breakage. Is there something I'm overlooking?
Old Oct 17, 2005 | 02:27 PM
white1's Avatar
Just remember, something has to give. If you're in loose dirt, or mud, it will probably be the dirt, but if youre on hard ground, or hit a root or something in a rut, it will probably be a driveline part or more. If you are ever going to use 4wd I'd deffinatly do both.
Old Oct 17, 2005 | 02:35 PM
NoChrome's Avatar
Id have to agree, besides I know from experience that you get what you pay for, go cheap now, pay big later.
Old Oct 17, 2005 | 08:54 PM
Pjstucn's Avatar
Thank you much guys, (mod can close this post now)
Idryfly5
Sep 2, 2022 08:55 PM
Oobray
Jun 13, 2022 03:38 AM
blownss27
Aug 14, 2020 08:27 AM
jtphelps289
Sep 29, 2015 12:00 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
