Question on a 2/4 drop
Old Jul 21, 2005 | 06:50 PM
Ruffrider5.3's Avatar
Default Question on a 2/4 drop
Will this affect launching? I want this thing lower to the ground. One it is a bitch to work on being so high and two it looks like a redneck owns it, ohh wait I may be a redneck. Where can I get a kit and how much?
Old Jul 21, 2005 | 07:17 PM
2k5Squirrel's Avatar
14 Second Truck Club
depends on how much you want to spend
hotchkis=$$$$$
groundforce/DJM/Belltech=$$$
Old Jul 21, 2005 | 07:34 PM
Mort's Avatar
Cool
I have a kit from McGaughys and they make a good kit. It use spindles up front and the ride is not changed much from stock as the stock springs are retained and there should not be any problem with alignment or turning radius. The Deluxe Kit is 9924DT #395.00 and requires 17" or larger wheels.
Hotchkis makes a good performance oriented kit that a lot of guys like for the improved handling but stiffer ride. The springs are shorter and stiffer for the front so the ride is a little harsher and the handling should be improved. Not sure if alignment will cause any issues.
A couple of other choices are Belltech and DJM Suspension .
All these kits have slightly different ways to achieve the 2/4 drop and the resulting performance varies a little from kit to kit. Launching should improve because there should be more weight transfer to the rear.
maxspeed05V
Nov 11, 2015 04:20 PM
Lamartian92
Sep 10, 2015 09:27 PM
USMCvet0311
Aug 1, 2015 07:45 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
KleanKustoms
Jul 18, 2015 10:08 PM
