putting a t-case on a 97 2wd
Old Jan 10, 2008 | 11:10 PM
whitesmokels1's Avatar
Default putting a t-case on a 97 2wd
so i have a 97 2wd c1500. im putting a dana 44 straight axle out of a 79 bronco under it and i want to use the stock transfer case they put in a 97 chevy 4x4. am i right on saying that its a 241? but my question is: will the case just bolt up to my transmission after removing the tail housing or what needs to be done?
Old Jan 11, 2008 | 07:18 AM
Lord Aries's Avatar
I think the np241 is the one you would want. On 4x4's the trans has a 4wd Tail housing, You will need that...
Old Jan 13, 2008 | 07:59 PM
is that all?
Old Jan 13, 2008 | 08:04 PM
no output shaft change?
Old Jan 13, 2008 | 08:38 PM
silveradol33's Avatar
you will need the longer output shaft, and a way to shift the case.
Old Jan 13, 2008 | 09:38 PM
kbracing96's Avatar
YA, you have to change the output shaft and to do that, you have to take all the guts out of the trans to get to 1 snap ring that holds it in. kinda a pita.
AHelm3
Apr 8, 2016 07:51 AM
mrhino
Aug 7, 2015 10:01 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
alex226
Jul 16, 2015 10:55 AM
Nimoryan
Jul 5, 2015 03:50 PM
