problem when I manually shift in 1st gear after transgo 4L80E
Old Apr 23, 2006 | 11:06 PM
Dark Halo's Avatar
Default problem when I manually shift in 1st gear after transgo 4L80E
the tranny shifts fine now in "D" but when I drop it into 1st the rpm's build then it starts to move then feels like it hits netural. I have a 03 4l80e with a transgo and 3800 pi triple disk stall.
Old Apr 23, 2006 | 11:11 PM
thunder550's Avatar
High on diesel fumes
Same thing happened to me, read from post #18 down.
http://www.gmfullsize.com/forum/showthread.php?t=42857
Maybe this will help a little...
Old Apr 24, 2006 | 06:46 AM
FLT's Avatar
FLT
FormerVendor
Are the rear band servo bolts tight with the metal shim gasket under the cover. In manual low the forwrd clutch is applied with also the rear band. How is reverse? Double check your directions make sure you didn't miss some thing.
Old Apr 24, 2006 | 11:05 PM
Dark Halo's Avatar
well today it was working fine and now I do not have reverse. In some fasion on the trip home today reverse stoped working and it fells like I have lost 1st gear.
Old Apr 24, 2006 | 11:33 PM
thunder550's Avatar
Probably burned up the reverse clutches and some of the forward clutches.
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
pittman
Jan 19, 2016 07:06 AM
lxcoupe
Jul 14, 2015 10:14 PM
zaathur151
Jul 6, 2015 10:57 PM
