pressure control solenoid X number of turns = X amount of line pressure increase
Does anyone remember how the pressure scales up as the set screw is turned in? IIRC its 1/4 turn = an additional 30 psi but my memory is terrible. I'm contemplating giving the 60E in the 99 a 20-30 psi increase when I change the fluid and filter. I'm not really after a firmer shift, just wanting a little more holding power on the clutches. I have zero faith in the 3-4 clutch pack on this thing.
Super old bump but I figure it would be better to bump up then to repost.
I plan on doing an filter change on my "built" 4l65e that shifts a bit firmer than I would like and I've already adjusted the shift pressures back to stock with HPtuners and I assume the screw has been adjusted.
I'd like to adjust it back down but don't know how much to.
help!
help!
03regcab sierra
20
Aug 3, 2015 12:11 AM
atxlt
Jul 20, 2015 11:06 PM
GMCtrk
Jul 17, 2015 06:39 PM
adjustment, control, gm, increase, increasing, line, ls1tech, number, od, pressure, prrssure, solenoid, turn, turns, xamountturns
