Please help 4wd transfer case removel !!!!
Old Dec 11, 2008 | 10:37 AM
BIRCHZ71's Avatar
Default Please help 4wd transfer case removel !!!!
is there a trick to getting this front drive shaft out? it wont come out!
Old Dec 11, 2008 | 10:48 AM
kbracing96's Avatar
Unbolt it from the front axle, take the little metal clamp off the rubber dirt shield at the back and it should slide right out of the transfer case...
thunder550's Avatar
High on diesel fumes
4 bolts hold it on to the front diff, push it backwards into the t-case , drop it down a little bit to clear the front yoke, and it should just pull out of the t-case.
Old Dec 11, 2008 | 12:27 PM
BIRCHZ71's Avatar
ok my trouble is removing the front driveshaft from the front diff.....all 4 bolts that hold the 2 metal straps are out but the i cant get the drive shaft to come loose.....it wont even budge and its holding up the entire process. please help!!!
Old Dec 11, 2008 | 12:35 PM
KySilverado's Avatar
Long screw driver up into the joint and pry it loose, careful not to damage the caps.
Old Dec 11, 2008 | 12:53 PM
BIRCHZ71's Avatar
thanks ky....i feel like an idiot now.....but hey its out.....also am i correct in saying if im just gonna seperate the transfer case from the tranny rather than drop the torsion cross member theres no piont in removing the rear driveshaft?
Old Dec 11, 2008 | 12:55 PM
Take the rear drive shaft out. Its easy, and pull the front drive shaft out of the transfer case also.
Old Dec 11, 2008 | 02:35 PM
03sierraslt's Avatar
+1 for everything these guys said. While you have it apart make sure you check the needle bearings on the U Joint.
Old Dec 11, 2008 | 03:06 PM
venomhp's Avatar
+1 again, with the driveshafts out of the way it makes things easier
Old Dec 11, 2008 | 03:07 PM
thunder550's Avatar
Yep rear driveshaft still has to come out. When you unbolt the t-case from the trans, it will have to slide back quite a bit to disengage it from the trans output shaft, then you will have to tilt it with the tailshaft housing pointed straight up to get it out without spilling any autotrac fluid. It would also be a good idea to pull the vent tube off of the nipple on top of the t-case and put a vacuum cap on there, otherwise you'll get fluid coming out the vent on the top.
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
