please help 4wd broke
Old May 10, 2007 | 05:16 AM
seeyaa's Avatar
Default please help 4wd broke
hey guys the 4wd switch is not light at all ive replaced the switch relay and fuse i have power at the swithch but no lights are one no ses light. but dont have a way to check stored dtc for 4wd.help
Old May 10, 2007 | 10:17 AM
Bish's Avatar
It is most likely the switch. Mine failed but gave me the "Check 4x4" message. I know when I took my old switch apart there were many "cold" solder joints. If you are decent with a soldering iron, I would suggest pulling the switch out and hitting any dull solder joints with the iron. If not, I don't think the switch is too expensive.
Old May 10, 2007 | 12:14 PM
seeyaa's Avatar
i put a new switch in but nothing, what solder on the harness or switch
Old May 10, 2007 | 02:19 PM
Bish's Avatar
Soldering was on the switch. If you take it apart, there is a circuit board on the inside. If you swapped the switch, I think you ruled it out as a cause. I will check my Helm tonight and see if I can give you any info on the pinout of the connector so you could test.
Old May 10, 2007 | 05:59 PM
seeyaa's Avatar
thanks man
Old May 11, 2007 | 12:07 PM
seeyaa's Avatar
anyone else
Old May 12, 2007 | 07:39 PM
seeyaa's Avatar
can someone give me any other idea is there a test procedre that might work i dont want to take to a shop,cash is aliite tite
lukn4trbl355
Oct 21, 2015 11:19 PM
Velocity1
Oct 2, 2015 08:01 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Blklgt
Sep 28, 2015 03:21 PM
sTNT971
Sep 26, 2015 04:22 PM
