please help 4wd broke
hey guys the 4wd switch is not light at all ive replaced the switch relay and fuse i have power at the swithch but no lights are one no ses light. but dont have a way to check stored dtc for 4wd.help
It is most likely the switch. Mine failed but gave me the "Check 4x4" message. I know when I took my old switch apart there were many "cold" solder joints. If you are decent with a soldering iron, I would suggest pulling the switch out and hitting any dull solder joints with the iron. If not, I don't think the switch is too expensive.
Soldering was on the switch. If you take it apart, there is a circuit board on the inside. If you swapped the switch, I think you ruled it out as a cause. I will check my Helm tonight and see if I can give you any info on the pinout of the connector so you could test.
lukn4trbl355
Oct 21, 2015 11:19 PM
Wrecker 426
Sep 30, 2015 09:39 PM
