Pinion shim question (nbs)
Old Feb 3, 2014 | 07:29 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Mr. Trick
It's a mcgaughys flip kit with 1pc drive line. So measure the trans, drive line, and pinion angle with a magnetic angle finder?
Yes. Use a magnetic angle finder.
Bump I really need help with this. my pinion angle is at like 13 and my drive line angle is at about 3
You want to get them as close to the same as posible.
Try about 6* and see if your within 3* difference.
Old Feb 3, 2014 | 11:38 PM
Mr. Trick's Avatar
12 Second Club
Thank you. I did end up getting a magnetic angle finder and that how I got those measurements.
I was thinking about getting the 6* shims so you just confirmed my thoughts thanks
Old Feb 3, 2014 | 11:44 PM
1FastBrick's Avatar
Let us know how it turns out.
Old Feb 3, 2014 | 11:47 PM
Blown06's Avatar
8 Second Truck Club
I had a 6* on my 6" drop and it didn't vibrate.
Old Feb 18, 2014 | 09:41 PM
Mr. Trick's Avatar
12 Second Club
Ok the major vibration is gone. It still has some slight vibration at around 70 but its not bone jarring like before. Now however the rear suspension is CRAZY stiff.
Old Feb 19, 2014 | 12:15 PM
TheSuspensionSource's Avatar
FormerVendor
My truck right now has a 6" rear drop with no shims but it has a terrible vibration, I am pretty sure it needs shims. Does anyone know which degree of shims I need? Also I plan to drop the back 2 more inches in the back
What year and cab size is the truck?
Old Feb 19, 2014 | 04:36 PM
Mr. Trick's Avatar
12 Second Club
2002 regular cab
Old Feb 19, 2014 | 05:04 PM
FormerVendor
2002 regular cab
I can't find why you would need one on a Reg Cab. Did you call McG's to see if they can assist you?
Old Feb 19, 2014 | 10:34 PM
Mr. Trick's Avatar
12 Second Club
I did not, but I will try that. I am using stock shackles from a 07 new body style truck so I don't know if that makes a difference.
Old Feb 20, 2014 | 11:08 AM
FormerVendor
Shackles shouldn't make a difference.
GXPJAY
Nov 5, 2015 06:49 AM
jtphelps289
Sep 29, 2015 12:00 PM
Tigger Welder
Sep 2, 2015 08:17 AM
mhotrodscooter
Aug 23, 2015 04:41 PM
USMCvet0311
Aug 1, 2015 07:45 AM
