pinion seal?
Old Dec 31, 2007 | 09:18 AM
Wilde Racing's Avatar
How do I change this text
Which ever way you choose. don't forget to replace the pinion nut...or at least use some healthy lock tite
Old Dec 31, 2007 | 11:25 AM
vanillagorilla's Avatar
You'll probably need a 2 jaw puller to get the yoke off. The pinion nut is 1-1/4", so you'll need a socket that big. Also a pipe wrench to hold the yoke/pinion gear while tightening/loosening the pinion nut.
It wouldn't hurt to pull the cover and drain the fluid. Mark a few teeth to see the pattern. Replace the seal and check the pattern again to make sure everything is jive. Just for some added peace of mind.
Old Dec 31, 2007 | 12:52 PM
MGMC's Avatar
12 Second Club
yeah i got a new diff gasket, fluid and such too. figure ill do it all while im there. thanks man
Chavette
Oct 28, 2015 07:33 PM
Tigger Welder
Oct 1, 2015 08:41 AM
97_ek
Sep 23, 2015 09:16 PM
fctry286
Sep 5, 2015 11:48 AM
