pinion angle
Old May 12, 2015 | 09:35 PM
George C....'s Avatar
Formerly ScreamingL
Old school setups for leaf cars and no bars ran -7 thru -9
Rules for street manors don't always apply to racing
Old May 12, 2015 | 09:37 PM
bigsapper's Avatar
Originally Posted by blown02408
The angle between the pinion and the driveshaft, and the tailhousing and the driveshaft should always be equal and opposite. The pinion and the tailshaft should also always be parallel to eachother. So if the pinion is set at -2 degrees to the driveshaft then the trans tailshaft needs to be +2 degrees to the driveshaft the resultant angle is 0 degrees. I just went through this with my truck which is lowered 7"s in the rear and ended up having to raise the trans mount 2-1/2"s and modify the engine mounts to make all the driveline angles happy again.
Great post. Clear and succinct.
Granted I should mention that I've seen some pinion angles in drag racing that defy logic, but work for some people.
My understanding is they set the angles to be 0 offset under acceleration load. So the typical static setup seems to be anywhere from -2 to -4 degrees of pinion offset. Bear in mind these are strip only setups.
Old May 13, 2015 | 12:02 AM
Blown06's Avatar
8 Second Truck Club
On leaf springs I generally like more pinion angle as the power goes up. Stockish truck.....2-3 degrees............mine when it was in the 10's........4 degrees.
Old Aug 9, 2015 | 08:02 PM
GMCtrk's Avatar
Bumping this back up for more info.
Obviously as power goes up, there's more force rotating the axle up hence the need for a larger pinion angle.
Now, does the pinion angle have an influence on how the truck will hook or is this all simply about reducing parasitic drivetrain loss?
I just measured my pinion angle at -2.5 degrees and I'm wondering if my axle is rotating up on launch with a positive pinion angle potentially 1 of the reasons I can't hook off the line?
Old Aug 9, 2015 | 08:29 PM
vmaxpro's Avatar
The angle between the pinion and the driveshaft, and the tailhousing and the driveshaft should always be equal and opposite. The pinion and the tailshaft should also always be parallel to eachother. So if the pinion is set at -2 degrees to the driveshaft then the trans tailshaft needs to be +2 degrees to the driveshaft the resultant angle is 0 degrees. I just went through this with my truck which is lowered 7"s in the rear and ended up having to raise the trans mount 2-1/2"s and modify the engine mounts to make all the driveline angles happy again. Granted I should mention that I've seen some pinion angles in drag racing that defy logic, but work for some people.
Glad to see someone else fought this. You got same as me. I trig'ed it out to be around 2.5". My exhaust hits the body so that required a serious hammer lol. What did you do to the engine mounts?
Old Aug 9, 2015 | 10:02 PM
vmaxpro's Avatar
From what I understand yes. Strapping a camera to the frame and watching that diff rotate on a hard launch will suprise you. An old drag car I had was running leafs and it would rotate 10 degrees.
Tigger Welder
Oct 1, 2015 08:41 AM
97_ek
Sep 23, 2015 09:16 PM
03chevytruck
Sep 10, 2015 10:18 PM
11MPG
Sep 8, 2015 04:52 AM
