Pinion angle
Old Dec 22, 2014 | 09:22 AM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
Default Pinion angle
What is everyone running their pinion angle at? Street / track duty. I'm pretty certain on how to find it with a 2 piece shaft. But correct me if I'm wrong, both shafts are supposed to be opposing angles ie +2, -2, and tail of Trans is supposed to be opposing of rear axle ie +3,-3. If both angles are negative then you subtract the lesser from the greater -6 and -3 = -3? And if you have a negative and a positive you add them -6+ +3 =-3? So if I had a desired pinion angle of -4, I would want something like -4,-8 or 0,-4? Does this sound right?
Old Dec 24, 2014 | 08:09 AM
BLKSSLTT's Avatar
bump** anyone??
Old Dec 24, 2014 | 04:17 PM
brandon6.0's Avatar
I just always go off rearend. shoot for -3*. Driveshaft does matter some but not as much as rearend.
Old Dec 25, 2014 | 12:18 AM
Jeebalow's Avatar
Here's a post that is my reply to another similar question. Open the manual (link in the post) from spicer it explains how to setup 2 piece driveshafts
https://www.performancetrucks.net/fo...9/#post5257206
Edit: Figure 8 and 9 on page 13 and 14 is what you should follow. 1 to 1.5 degrees from trans to front shaft, pinion parallel to front shaft and no more than the max recommended angle for your u joints between front/rear shaft and between rear shaft/pinion.
Tigger Welder
Oct 1, 2015 08:41 AM
97_ek
Sep 23, 2015 09:16 PM
03chevytruck
Sep 10, 2015 10:18 PM
11MPG
Sep 8, 2015 04:52 AM
