Parts Guy: "Lowering a truck will not cause a vibration....."
Old Mar 16, 2012 | 11:44 AM
  #21
Ferocity02's Avatar
Originally Posted by dlt76028
Dear lord thats horrible, and you should have the fat side of the shims forward...
Hah, the shims were in there from when I installed shackles years ago (which I was told to do fat end back), then I did hangers two weeks ago and didn't change the shims, so yes they are in the wrong way. Funny thing is, I only get a slight shudder taking off from a dead stop, and a little vibration from 15-25mph, nothing else. I'm going to raise the carrier bearing and flip or remove the shims (if I need more than 2*). Might need 6* like Black here.
Old Mar 16, 2012 | 12:23 PM
  #22
TXsilverado's Avatar
the fat side facing the front of his truck would kick the pinion up even higher. to point the pinion down some the fat part would need to point at the shackles.
Old Mar 16, 2012 | 12:46 PM
  #23
Ferocity02's Avatar
No, fat end forward will rotate the pinion of the diff down toward the ground.
Old Mar 16, 2012 | 12:54 PM
  #24
smokeshow's Avatar
Mod with training wheels
Fat end forward picks up the pinion.
Old Mar 16, 2012 | 12:57 PM
  #25
i'm an idiot...i have a flip kit so everything is exact opposite. durrrr yes fat end forward to drop the pinion on a non flip kit truck
Old Mar 16, 2012 | 12:59 PM
  #26
smokeshow's Avatar
Hm I was on your train of thought too. lol...been helping a friend with his flip, ***** all backwards
Old Mar 16, 2012 | 01:25 PM
  #27
BlackGMC's Avatar
Resident Retard
Hmmmm. Well..... I am pretty trad-er-ific..... I got everything apart and i am bolting up the shims and i noticed the passeneger side leaf spring was kinda flopping around. Appartently the damn nut that holds on the front side of the spring decided to exit the vehicle. Sooooooooo the bolt is just moving around freely. Luckily i have drop hanger and the frame was keeping the bolt in place. No telling how long it has been like this.....
Old Mar 16, 2012 | 03:17 PM
  #28
Robert91RS's Avatar
Corey...I have a theory about your vibration lol
Old Mar 16, 2012 | 03:30 PM
  #29
put a butt plug in and enjoy it!
Old Mar 16, 2012 | 03:57 PM
  #30
BlackGMC's Avatar
Resident Retard
Well it is all fixed. I put a nut on the damn leaf spring bolt.
And
I put in a 6* & 2* shim. Not my rear end points down -2* and the drive shaft is at 2*. Sooooo i am at -4* static. I decided not to replace the leaf spring bushings at this time. Truck drives good. Took it up to 90mph and it was smooth as glass.
